C2 Rear Main Seal GM10121044 - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Just picked up the GM flouroelastomer rear main seal and have a few comments/questions.
    First, the package does NOT contain the little plastic shoe-horn. Is this only used on the neoprene seals or is it also recommended for the flouroelastomer unit as well?
    Secondly, the supplied GM instruction sheet says to be careful to keep sealant off of the ends of the seal. Should sealer be applied to the mating ends of the flouroelastomer seal in addition to the bearing cap mating surface?
    Lastly, is it a good idea to rotate the seal a few degrees (3/8 in) so the mating halves of the seal are offset from rear bearing cap mating line?
  • Jim R.
    • June 30, 2001
    • 643
    Re: C2 Rear Main Seal GM10121044
    It is a good idea to rotate the seal it will help prevent leaks.
    JR
    • Bill S.
      • August 31, 1999
      • 104
      Just did a rear main seal on a 68 here is the procedure:
      Corvette hacks
        Bill -
        The write-up is very specific about NOT getting any RTV on the seal split line, but the photo of the main cap shows RTV both on the cap mating surfaces AND on the ends of the seal?
        • Bill S.
          • August 31, 1999
          • 104
          Re: C2 Rear Main Seal Update
          I corrected the procedure in the article. The picture of the sealer on the seal is correct (as per shop manual)
          Bill
          Corvette Hacks
          • Paul L.
            • November 1, 2002
            • 1414
            These instructions came with GM #31022667 for my 1979.
