C2 Battery Disconnect - NCRS Discussion Boards
  • Craig C.
    • July 31, 1996
    • 27
    My "spring ring" style battery cable terminal seems too large for the post on my battery disconnect switch. Is there a way to install a battery disconnect switch using "spring ring" terminals? Thanks, Craig
  • William C.
    • May 31, 1975
    • 6037
    Re: C2 Battery Disconnect
    Are you trying to put the disconnect on the positive or negative side? The negative battery cable is sized for a smaller battery post than is the positive cable.
    Bill Clupper #618
    • Kent K.
      • December 1, 1982
      • 1139
      Agree with Bill
      Mine is installed on the negative terminal and has dine fine for a number of years.
      Kent #6201
      Kent
      NCM Founder - Member #718
      • Craig C.
        • July 31, 1996
        • 27
        Upon further review, it fits OK. I originally thought the disconnect post was smaller than the small neg. battery post, but they are the same so the "spring ring" fit is fine after all. I apologize for the error. Thank you Bill for your response. Craig
