Does anyone have any secrets on mounting the whiskers at the top of the doors both inside and outside to the stainless support pieces.
'61 window whiskers
Re: '61 window whiskers
No secrets to it. Mark where the original was very carefully. Put the replacement exactly in the same place. I used the original holes in the stainless, used my drill to go through those holes and through the whiskers, and then bent the staples. measure twice. drill once- Top
Measure twice, drill once, AMEN. I just did this for my 60, broke three drill bits, ended up using a sharp ice pick to force the hole in the whisker. A fellow at a local restoration shop suggested creating a complete assemble using the door post and stainless to identify the proper location for your car. I did this and taped the new whiskers to the stainless, the dissasembled and attached the whiskers to the stainless carefully. Good Luck!- Top
