'61 window whiskers - NCRS Discussion Boards
'61 window whiskers
  • Ernie Cope
    '61 window whiskers
    Does anyone have any secrets on mounting the whiskers at the top of the doors both inside and outside to the stainless support pieces.
  • Mike E.
    • February 28, 1975
    • 5134
    Re: '61 window whiskers
    No secrets to it. Mark where the original was very carefully. Put the replacement exactly in the same place. I used the original holes in the stainless, used my drill to go through those holes and through the whiskers, and then bent the staples. measure twice. drill once
    • David Dawdy
      Measure twice, drill once, AMEN. I just did this for my 60, broke three drill bits, ended up using a sharp ice pick to force the hole in the whisker. A fellow at a local restoration shop suggested creating a complete assemble using the door post and stainless to identify the proper location for your car. I did this and taped the new whiskers to the stainless, the dissasembled and attached the whiskers to the stainless carefully. Good Luck!
