Re: Does this mean a TI ignition doesn't...
The TI has a resistance wire in the harness, but it's less than one ohm. Since the TI (Transistor Ignition) uses TRANSISITORS to switch primary current, there are no points and the transistors can handle higher primary current, which nets greater ignition energy. The HEI module packs all the TI amplifier circuitry into a thick film hybrid module and adds some other neat stuff such as variable dwell, which helps maintain energy and voltage at high revs. The conventional single point ignition supplies about 41 millijoules per spark. Both the TI and HEI deliver about 75 millijoules, but the HEI is much cheaper and more reliable than the TI. I think its one of the most elegant designs GM ever produced. It's long duration spark is perfect for a street engine, and I've never understood why people spend hundreds of dollars on aftermarket ignitions to replace the HEI.
