It hasn't mattered too much since we're into warmer weather, but I recently found my heat riser valve to be sticking open. It won't "free-wheel" on it's own, but it will move, and I have tried WD40. If I close it by hand, it will open when it gets to temp.
Is there anything I can use that won't "burn off", do I need to remove and clean it, or is it on it's way out? The only time I've really seen a "bad" one was when they were rusted solid shut, and the one time I've had this one off it appeared fine. Just thought I'd check before I start unbolting stuff. TBarr #24014
