I am routing the positive battery cable on my 67. I go to the AIM in the back under battery cables C-60. My car has no evidence of ever having all the battery cable clips shown in the AIM. I have the 2 on the left by the starter and the one up on the flat area behind the distributer. The next 2 are shown one on top of the other. I have the lower one for the ground cable. I also do not have the one behind the battery. These clips are riveted on and I have no holes in my firewall. Is this unusual? Kent what do you have? This is an original March 30th car. Thanks in advance Dale
67 SB with C-60
Tags: None
Re: 67 SB with C-60
Hello;
'22684 vert. 350 hp P.S. A/C
Negative;
Under str. column 1 1/2" toward the center of car.
Positive;
Left of Master Cyl.1" beneath.
Straight behind left valve cover on the horizontal.
Straight behind rt Valve cover on the vertical.
Hope that helps.
RayAnd when you get the choice to sit it out or dance
I hope you dance
Re: 67 SB with C-60
Dale - The battery cable clips on the firewall of my mid-production run '67 are exactly as shown on page C60-E3 of the AIM.Kent
NCM Founder - Member #718- Top
You have mail
Dale - I emailed a tracing to you of the upper part of my alternator brace as you were asking about it in an earlier post.
Kent KeechKent
Re: You have mail
Thanks to all on the battery cable clips. The two under the steering column one for negitive and the one above it for positive( as per the AIM) are there but hidden. The one behind the battery was never there as there is no clip or hole for the rivet or rivet that held the broken off clip. Must have been missed. A special thanks to Kent Keech for his drawing of the alternator brace on a 67 SB C-60. Thanks to all who helped. Dale- Top
