64 voltage regulator mounting ?
  • M. Craig Willetts (36551)
    • August 1, 2001
    • 835
    Hi all,
    I am trying to figure out how my voltage regultor on my 64 300 HP is mounted to the firewall. Yes I know it's mounted with three screws but its the small rubber coated bolts that I am stumped on. Do these mount through the firewall and as you tighten the screw it expands to hold it or do they attach from the opposite side? Truly a picture would be worth a thousand words for me here if anyone can help.
    Thanks so much as always,
    Craig
    #36551
  • Phil Philson (45550)
    • April 1, 2006
    • 409
    well nuts- available at most hardware stores *NM*
      • August 1, 2001
      • 835
      Re: well nuts- available at most hardware stores
      Can you provide a picture of how it looks? Well nuts are a bit different than what the AIM show's.
      Craig
      • Jack Humphrey (17100)
        • April 1, 1990
        • 9893
        Pictures sent by off-board email... *NM*
        • Peter Lindahl (6598)
          • June 1, 1983
          • 1930
          The drawing in my 64 AIM, Sect 6, Sheet B4.00, Item 2 Nut shows what I would expect a "well nut" to look like. In the 1953-1972 Corvette Parts Catalog the Nut is in G/N 2.500, p/n 3876130 and is listed as folows:
          64-72 Corvette, NUT, w/ grommet regulator (No. 10-24).
          The ones I have in my parts department read
          WELLNUT-PAT - L-1024.
          Follow Phil's advise and hope this info helps.
          Pete
            • August 1, 2001
            • 835
            Thanks all. *NM*
