C1 Rear end Spring Perches and Rear Housing ??s - NCRS Discussion Boards
  • Ted S.
    • January 1, 1998
    • 747
    Well in the process of the restoration of my '58 indications are it appears to have had a rough life (or maybe it's rear end problems are more common than I think). A few of questions for the board. Does anyone make the spring perches for the rear end? Are they supposed to be curved to match the arch of the rear springs? Anyone out there have a vette posi housing they're willing to turn loose of?
    The perches on mine are curved but it doesn't look like they're bent, there are cracks in the welds, and the locating pin holes are are egg shaped rather than round which I assume is wear. At some point they had tighted the U bolts enough to make divits in the housing. You could even feel them on the inside of the axle tubes.
    Ted
  • Terry D.
    • May 31, 1987
    • 2690
    Re: C1 Rear end Spring Perches and Rear Housing ??
    Ted
    Don't know anyone making the perches, you might try the vendors that deal in used parts, Mary Jo, Grossmuellers Paragon, etc. You could also try try the55-57 chevy sources. Might be easier to just get them rewelded.The divits in the housing should not hurt anything.
    As for the housing again the used parts vendors or E-Bay.
