1959 C1 Borg Warner Trans - NCRS Discussion Boards
  • Jack M.
    • April 1, 2007
    • 26
    Can anyone provide some insight on my transmission and whether it's correct for the car? My Vette was build around July 2nd 1959. The transmission Main Cast is a T10-1B dtd WF1992, Side Cover plate is a 59 Style according to judging manual but I haven't taken the cover off to see the date (assuming it correct) and the tail housing is a T10-7A dtd 3 9 59 M. I've been told that the transmissions are only judged for correct type. Is that correct? Does this transmission pass the test for my car.
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    I would say your transmission will pass...
    ...the test for your car with no problems.
    • William C.
      • May 31, 1975
      • 6037
      Re: 1959 C1 Borg Warner Trans
      If anyone looks hard enough to see the casting ID, the '59 is a T10-1 case. Yours is a 1961 case.
      Bill Clupper #618
      • Ray C.
        • June 30, 2001
        • 1132
        Is the case aluminum or iron?
        Ray
        Ray Carney
        1961 Sateen Silver 270-HP
        1961 Fawn Beige 315-HP
        • Jack M.
          • April 1, 2007
          • 26
          Thanks Bill,
          How can I tell it's a 61 case, It is stamped dtd June 19 1959 2nd shift on the cast iron case itself. I was told that the T10-1B cases ran all the way through late 1959.
          • Jack M.
            • April 1, 2007
            • 26
            Ray, The case is cast iron. Correct for this year and date.
