I have a few questions regarding correct bolts for my 71 coupe.
What design,markings etc. should hold the rear outer (the long ones) bumper bracket to the frame? Mine had regular lock type washers on it and it appears that the bracket has some markings as if the larger serrated/self gripping type washers may have originally been on it. (which leads me to believe the that the bolts holding mine in may not be original).
Also, my muffler hangers had one bolt type on one side and another on the other side. Any help regarding the marking, length, style, etc. that I should be using? One side had a bolt with a taper at end of threads and a nut with a flange (not sure what the marking were - but can check) and the other side had a longer bolt which was not tapered at end of threads and a nut which did not contain a flange. I have no idea if one of these is correct or neither is correct.
