327-350 hp original stamp??? - NCRS Discussion Boards
  • Alan Wilson
    Re: 327-350 hp original stamp???
    Heres all I know. Let me know if these numbers all fit. I think they do:
    68 327/350 Vert, M21 close ratio
    Est. birth date 10/4/67
    Block Stamp V0927HT 18S401273
    Block cast date I147
    Block cast part# 3914678
    Heads Cast date H257 and I57
    Head cast part# 3917291
    Intake Manifold cast date I117
    Intake manifold cast part# 3919803
    Water pump cast date I197
    Water pump cast part# 3782608
    Distributor band 1111438 some Orange paint still there.
    What should the Muncie numbers be?
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      I'm not as familiar with the C3's, but the spec guide says:
      1968 194678S400001 - 428566 (28,566 made)
      1= Chev, 9=Corvette, 4=V8, 67 or 37 = coupe or conv, 6th digit = last digit of year, S= St Louis Assy, then 6 digit serial #
      Could your eng stamp be "7"8S401273? maybe I'm wrong, or your typo? I can't find the derivative info in the spec guide.
      Block 3914678 , yes 327 300 & 350 hp
      I147 Cast Sep 14, 1967
      V0927HT Assy date Sep 27 327,350hp, L79 option code, Roch Qjet, Spec Cam, 4 Speed. I'm not sure about the "V". Anyone??????
      Heads look right 300, 350hp 327ci
      Intake yes, cast iron, 300, 350hp 327ci
      Dist, yes, 350hp, 327ci
      Book doesn't show water pump.
      4 speen Muncie Transmission should be "P" "stamped vertically on right side of case, lower rear, just ahead of transmission extension" and I think assy stamp date and the vin derivative also. Book is unclear. Anyone else?
      Hope it works,
      Rich
      • Alan Wilson
        #18
        I think the V means Flint Michigan. So to clarify are you saying the part numbers look good or also that the timing of the dates seem about right?
        • Alan Wilson
          #19
          Your right about the 7. The vin number of the car is 194678S401273
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11302
            #20
            Hi Alan,
            By the book, yes all numbers look perfect, and the dates appear to be right in the range of the build. As long as that "V" is correct. That's the only thing I couldn't find in the book. Probably correct as everything else is.
            The thread is a bit old so maybe others more knowledgable than me haven't seen your posts. It'd be good for a C3 expert to confirm what I read out of my spec guide. You can get one from the NCRS store online. I have the 53-72 original spec guide from 1989 which came as a quarterly magazine in place of the Restorer. I have the pocket guide but it's the 1997 version which stops at 1967.
            Rich
            p.s. I think you have a piece of "history" there! Good Luck!
            • Alan Wilson
              #21
              Thanks Rich!
              I have already started a new post to get other opinions. I will also take your advice and get a C3 experts opinion.
