cam for 63 300hp - NCRS Discussion Boards
cam for 63 300hp
  • Sander B.
    • March 1, 2005
    • 499
      • 15610
      Re: cam for 63 300hp
      I'm sure virtually everyone knows this but the 350 HP (L-79) engine used the 2.02/1.60" valve set and had a high performance HYDRAULIC lifter camshaft - 3863151 along with other differences including pistons, crankshaft, inlet manifold, torsional damper.
      Both the 300 and 350 HP engines used the same head castings (...461 through '66 and ...462 in 1967), but the 300 HP engine used the "standard" 1.94/1.50" valve set and the 3896929 camshaft, which was widely used in Corvettes, passenger cars, and truck small blocks from '67 through about 1980, so it is a very common cam - millions were produced for OE engines.
      The spec sheet is likely okay since it's from the manufacturer, but your retailer is completely confused about the specifics of the configurations.
