Re: WARNING!!!
it is not a big deal,just make sure you fill the carb,have the timing set as close as possible,prime the oil pump and if it does not start right away check the timing. i always have my timing light connected up before i try to start the engine so i can set the timing as soon as it fires. set the idle speed up on the carb so after you pump the throttle a few time,hit the starter to keep the speed between 2000 and 3000 RPM for 10 to 15 minutes. check for leaks and keep a check on the water temp and shut it down if it starts to over heat. the best way is to place a large fan in front of the rad to help cool the engine. it is best if you have a helper in the car to keep check on the water temp and oil pressure.
