GM part identification
  • Bruce Bursten (27670)
    • June 1, 1996
    • 2930
    Can anyone identify the follow GM part numbers?
    6270119, 1941119, 179358, 6264018, 3968665 and 3877345.
    I have looked in my GM 1953 to 1972 parts catalog with no luck.
    Any help will be appreciated.
    Bruce B.
  • Joe Lucia (12484)
    • 42936
    Re: GM part identification
    Bruce------
    Well, you've got some strange ones here. Where did these numbers come from? Off of a part or off of a parts box or label? Anyway, here's the little I can find:
    6270119----This was some sort of assembly used in PRODUCTION but never available in SERVICE. Its component parts were serviced, but I have no information as to what they were. I'd guess this piece dates from the early 70's;
    1941119----no record, at all. Likely some sort of Delco part;
    179358-----no record, at all. Likely some sort of fastener;
    6264018----stabilizer link bushing also used for some shock absorbers. Applicable to 1953-82 Corvettes as well as a HUGE number of other GM cars and trucks;
    3968665----no record, at all. This part was likely released about mid-to-late 1969;
    3877345----no record, at all. This part was likely released about late 1965 or 1966.
    Keep in mind, that if you find these numbers on actual parts, that does not necessarily mean that it is a finished part number. It could be a component of an assembly that was never available in SERVICE. It could be a casting number that is not the same as a finished part number. Also, they could be PRODUCTION-only part numbers which were never available in SERVICE. I can usually do pretty well with part numbers that were used both in PRODUCTION and available in SERVICE (most parts are both). However, for parts that were PRODUCTION-only, my informational resources are much more limited.
    • Joe Lucia (12484)
      • 42936
      Bruce------
        • June 1, 1996
        • 2930
        Joe,
        Thank you for the information and your efforts.
        The part numbers are from a pile of parts I hope to get from an old Corvette guy, sort of like me.
        I identified most of them (35 out of 41) but these were not found.
        When I get them I will post the descriptions if they are interesting.
        Most of them were bought in the late 60's and early 70's.
        Thanks again and the resources you and the other people provide are great.
        Bruce B
          • June 1, 1996
          • 2930
          Joe,
          Bruce B
          • Joe Lucia (12484)
            • 42936
            Bruce-----
            With more information on the ones I wasn't able to ID, I might be able to come up with something more.
            • Joe Lucia (12484)
              • 42936
              Bruce-----
                • June 1, 1996
                • 2930
                Joe,
                I should have the parts in a few weeks, if I can't figure out what they are I will contact you.
                Thanks again for your help.
                Bruce B.
                  • June 1, 1996
                  • 2930
                  Joe,
                  Bruce B.
