Delco carburetor kit - NCRS Discussion Boards
  • Lyndon S.
    • April 30, 1988
    • 1027
    I came across a power carburetor kit with 7039222 and 1#9222 on the package. Is this the right kit for a 7041205 carburetor? Also this kit has never been out of the package, do you think it is still good to use on a rebuild?
    Kelly
    Re: Delco carburetor kit
    Kelly-----
    Yes, the GM #7039222 kit is applicable to the GM #7041205 carb. Most likely, most, if not all, of the components of the kit will be fine. I would check any paper or cork gaskets for signs of drying out and becoming brittle, though. I think they will be ok, however.
      Kelly-----
      • Clem Z.
        • January 1, 2006
        • 9427
        the problem with these older kits is the pump diaphragm material is not compatible with the newer gasoline blends containing alcohol.
        • Clem Z.
          • January 1, 2006
          • 9427
            clem-----
            Yes, I can see how that could be a problem; I should have thought of that. Also, the other gaskets in the set might also be less resistant to modern fuel blends. So, that's a good reason to forget about NOS carb rebuild kits and just buy a modern, up-to-date kit (Borg-Warner or other brand).
              clem-----
              • Clem Z.
                • January 1, 2006
                • 9427
                you need viton accelerator pump diaphragms and if the one in the kit is black it will hardened with these new fuels.
                • Clem Z.
                  • January 1, 2006
                  • 9427
                  • Lyndon S.
                    • April 30, 1988
                    • 1027
                    When you say NEW FUELS your talking about a ethanol based fuel? Are you talking about something else?
                    Kelly
                    • Lyndon S.
                      • April 30, 1988
                      • 1027
                      Kelly
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        most gasolines have 10% ethanol now to help with emissions or octane rating
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          • Clem Z.
                            • January 1, 2006
                            • 9427
                            PS
                            i have a Qjet carb here now that the black pump cup is as hard as a lump of coal. it broke into several pieces when i tried to remove it.
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              PS
