I was about to put my water pump back together tonight but then I noticed conflicting figures. The instructions that came in the kit from ZIP says that the impeller to housing clearance should be .010" to .0135". The 1969 Chassis Overhaul Manual says that it should be .10" to .035...quite a difference.
Who do you think is correct?
I would assume that the chassis manual is correct but I'd like at least a second opinion on that.
Thanks.
Greg Linton
#45455
Thanks.
Greg Linton
#45455
