64 anti-sway bar end links - NCRS Discussion Boards
  • George D. #31849
    Can anyone please let me know the proper procedure to replace the front anti-sway bar end links in my 64? I want to make sure I do it right and I am quite the novice.
  • Dennis F. King
    Re: 64 anti-sway bar end links
    George
    This is a very easy job, safety is formost.Get a helper! You can put your car on ramps (best way) or up on jack stands. (chock the rear wheels). The main thing is don't let your suspension drop, so if you use jack stands place them outboard as much as possible under each lower control arm.It will go much easier with that helper. Before you release the nuts look at how the washers/bushings and spacers are stacked, then you and your helper do each side together. Reverse the procedure and your done. If your car is not being judged you can double nut the top nut to keep it from backing off.
    Good luck, have fun! Dennis
