If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
Has anyone removed old paint/dye from dash pads or have any tips. My 65 dash was painted at some point in it's life and is now flaking off so I need to get all of this stuff off so I can re-dye them.
Really don't want to buy new pads as these are not cracked anywhere.
My dark blue dash pads had been painted black. I used 3M Adhesive Remover to remove the black paint from the pads. It will take multiple passes as this solvent does not appear to be too aggressive. After that I cleaned them well with lacquer thinner, sprayed a vinyl primer and then re-dyed them blue. The dye adhered well and they still look good three years later with no lifting.
I use Dot 3 brake fluid. It works well and will not damage the vinyl unless you get too aggressive scrubbing it. Best to let it sit and then carefully scratch at it with something like a soft scrub brush.
Extremely hot water also will work depending on how well it is stuck on. Yours sounds like someone did a poor job. That is good for you because it is easier to remove.
Someone recently told me they used water soluable paint remover?? I have not tried that. I would be careful no matter what method you use. Terry
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
