C2 Carter Carb Question - NCRS Discussion Boards
    • August 31, 1999
    • 155
    Just pulled the AFB off of my '65 327/300 mt. car to send it off for rebuild/restoration. The ID # on this carb is 3721 SA with K4 stamped below the 3721. The NCRS Spec. Guide calls for a 3721 SB. Is there a significant difference between the SA and SB? Is this carb incorrect as far as Flight judging goes? My car, VIN18420, was built on 25 May, 1965.
    Thanks. . .
    Re: C2 Carter Carb Question
    Jack-----
    As far as I can tell, they are functionally identical and can be used interchangeably. As far as whether only the "SA" is considered correct for judging, I don't know.
      • August 31, 1999
      • 155
      How 'bout the "K4" stamp? Is this manufacturing date-related maybe?
        Jack -
        The "K4" signifies October, 1964.
          • August 31, 1999
          • 155
          OK, then is this carb correct for a May '65 L75 mt?
          • Page C.
            • February 1, 1979
            • 802
            In my opinion, that would be a stretch. 8 months is not your typical time frame on the 3721 AFB's. I would think a March or April of 65 would be a better fit. Suggest that you check with whoever is going to restorer it and see if he has a closer dated AFB.
            Regards
            Page Campbell
              • August 31, 1999
              • 155
              Good idea! Thanks to you and Joe and John for your responses.
              Jack
                • August 31, 1999
                • 155
                One more question. For a L75 car built the third week of May, 1965, should the 3721 SB carb have an April (G) or May (H) date code? I intend to exchange my 3721 SA (K) for a date-correct carb, if possible.
                • Timothy B.
                  • April 30, 1983
                  • 5177
                  Jack,
                  I would go with the April date for the 3721. I don't know when the change from SA to SB took place so you better check before exchanging your carburetor. I believe the difference between SA/SB is jets, metering rods and also air bleeds located in the primary venturies.
                  • Mike McKown
                    I'm thinking there was a TSB that covered the SA/SB carbs?????????????????
                    • Dwight P.
                      • June 30, 1983
                      • 176
                      Jack:
                      According to the 65 Judging Manual(Page 94)the changeover from SA to SB occured approximately November 1964. Your car shoul have a 3721SB dated sometime prior to 25 May.
                      DP
                        • August 31, 1999
                        • 155
                        Thanks one and all. This information was extremely helpful.
                        jackcasa
                        • Clem Z.
                          • January 1, 2006
                          • 9427
                          the SB specs are rod #16-388,.073 X .060,pri jet 120-224,.099, secondary jet 120-176,.067. the SA was jets .104,.0689, rod .060 X .069
                          • Timothy B.
                            • April 30, 1983
                            • 5177
                            Clem,
                            That's a big jump to the lean side from SA to SB. There is good archive info from years ago about these specs, I believe the 1963 Corvette 3461S carburetor has the same jets and metering rods as 3721SA.
                            • Clem Z.
                              • January 1, 2006
                              • 9427
                              i got these numbers from a original carb i rebuilt. i was supprised when i saw what was in it but checking farther i found out it was correct.
