Power Top Trivia
  • Roy Braatz (182)
    • February 1, 1975
    • 7044
    Power Top Trivia
    Left pic is Car // right pic isCorvette // nice to know that the car handle & shaft, aluminum housing, steel holder mount, and many inner parts and clips are the same as Corvette.
    The reason the car has four connections is because the top motor runs in two direction back & forward, where as the Corvette top motor runs in only one direction .
  • Roy Braatz (182)
    • February 1, 1975
    • 7044
    Re: Power Top Trivia toggles 56
    L/top toggle switch pic. seats on the gas tank and R/top pic. is the wire and retainer that screws to the top frame=R/S , the wire connects to both( any year soft top frame 56 to 60 "could" have the screw holes for the retainer PT Corvette or not).
    L/bottom pic. toggle switch located in the trunk area( all three items are 56 only!
    R/bottom pic. is the breaker A40 amp, this little thing is just that a (breaker)people with a power top Corvette have experience the top stopping mid-way Right! Because that breaker gets hot and breaks the hot connection. You waite a while then the top starts working. P/windows connect to the same breaker and can stop working to if it gets to hot.
    It took me a while back in the late 60's to understand how to make a PT work and rebuilt many for guys and wrote about them.
    • Mike McCagh (14)
      • June 1, 1974
      • 8288
      roy: i think ya got it wrong. the one on the left is like the switch in my 56 and 57 vette. don 't know what a pass car power top switch looks like so can't comment on what the one on the right is appropriate for. mike
      • Roy Braatz (182)
        • February 1, 1975
        • 7044
        Re: Power Top Trivia "Mike
        Man I cant tell my left form my right , your right , glad to see you keeping me honest.
        That the problem not being able to edit a post once it's posted with out deleting it..
        • Gary Chesnut (5895)
          Administrator
          • October 1, 1982
          • 16792
          early 56 Power Top different?
          Roy, was reading some old info today on power tops which said the early '56 power tops were unique unto themselves. Do you know if that's correct or not? Thanks, Gary....
          Shopping online for all your Home/Work/Auto needs?
          click here to support the NCRS Foundation Scholarship Program
          • Roy Braatz (182)
            • February 1, 1975
            • 7044
            Re: early 56 Power Top different?
            only the switchs, soft top frame and wireing
              Administrator
              • October 1, 1982
              • 16792
              Roy, was there anything visible or was it all hidden behind the trunk cardboard. Thanks, Gary....
              • Roy Braatz (182)
                • February 1, 1975
                • 7044
                only the trunk safty switch can be seen good
                  Administrator
                  • October 1, 1982
                  • 16792
                  Roy, do you have photos you can post or e-mail me of the two different switches? Thanks, Gary....
                  • David Dawdy
                    Roy -
                    I still have your handout from Copper Mountain re: power tops. At that time I had an early 56, number something like #479. I am currently getting a power top - power window 60 ready for display at the St Charles meet in St Louis. It has the 40 amp breaker that you display, I also have a 30 amp breaker, what was its application?
                    • Roy Braatz (182)
                      • February 1, 1975
                      • 7044
                      I think it's the A20 base is longer then the correct A30 amp, but they were used for many other cars. The A30 is what you use.
                      • Rob Dame
                        Gary, what two switch pics are you looking for? Rob
                        • Garry Barnes
                          Gary,
                          I can provide you with photos of my old '56 PT switches and harnes before the restoration if you want them. Let me know.
                          Garry
                          • Roy Braatz (182)
                            • February 1, 1975
                            • 7044
                            Gary my pic show the two switchs *NM*
