Powerglide dip=stick
  • Mike Noguera (35882)
    • April 1, 2001
    • 110
    Attached is a picture of the trans dip-stick I in my 1957 Powerglide tranny. I don't know if it is original or not.
    Someone requested I send a picture of the handle.
    LG,
    Mike
  • Roy Braatz (182)
    • February 1, 1975
    • 7044
    Re: Powerglide dip=stick (YES) *NM*
    • Bert Levesque (1392)
      • May 1, 1977
      • 416
      Would this dip stick configuration be appropriate for 1960 also?
      Thank you.
        • May 1, 1977
        • 416
        Message above was posted before I had read prior Powerglide thread, however
        is it correct to assume that 55 to 61 cast iron PGs all had same dipstick,
        dipstick tube and dimensions and markings. Mine was broken now brazed and
        unsightly, need replacement for my '60.
        Thanks again,
        Regards to all,
        Bert
        • Roy Braatz (182)
          • February 1, 1975
          • 7044
          Bert YES *NM*
          • Don Steele (33609)
            • February 1, 2000
            • 476
            Roy-- can you fill us in on the difference between the 53-4 dipstick and the 55 dipstick
            • Roy Braatz (182)
              • February 1, 1975
              • 7044
              DON
              Don/ believe it or not I don't have a pic. On hand to show you but the 53 to 54 stick is easy to tell from a 55. The 53-54 head has a nut looking design while the 55 head is round, hard not to notice. I don't think it's mentioned in the JM.
              Remember you have a 55 and how often do you see one (a 55 Corvette) your 55 must be looking better with your concern about correct parts.
