C2 67 A/C SMALL BLOCK IGNITION SHIELDING - NCRS Discussion Boards
  • Terry S.
    • January 1, 2006
    • 45
    While trying to install the right front ignition shielding it interferes with the A/C bracket. Is this piece of shielding eliminated or is there a different piece or ?? Any help would be appreciated.
  • Joe R.
    • March 1, 2002
    • 1356
    Re: C2 67 A/C SMALL BLOCK IGNITION SHIELDING
    Hi Terry:
    When I got my car the shielding under the compressor was missing, but I got a deduction for it during judging, and when I checked the AIM it showed it being installed.
    I was able to install a repro shield, but I recall that one of the brackets that holds the upper shield in place is mounted on a stud that replaces the forward-most exhaust manifold bolt. I had to remove the compressor mount to install the correct stud. Once I did that, everything fit fine.
