Found My AOS Job Number Today!? - NCRS Discussion Boards
  • Kirk McHugh
    Re: Found My AOS Job Number Today!?
    Nope, just a white number 14. Nothing else. Guess it isn't the job number then?
    • Kirk McHugh
      That looks almost identical to mine. So whatever it is, they were clearly doing it on multiple cars!
      • Kirk McHugh
        #18
        • Kirk McHugh
          #19
          Just re-keyed my car ignition to match the original door key locks. Can't remember the key lock number, but I think Pete wrote it down for me. I will check his notes tonight at home and see if it matches. Although the large number posted above would hardly represent a key number would it???
          • Kirk McHugh
            #20
            • Barbara S.
              • April 30, 1981
              • 599
              #21
              I don't think the letter is on the metal brace behind the dash on an A. O. Smith car. It will be on the job number on the bulk head in front of the gas tank, and on the passenger side firewall.
              Tony
              • Barbara S.
                • April 30, 1981
                • 599
                #22
                Tony
                • Kirk McHugh
                  #23
                  So, is your thought that it represents a "shorthand" of the job number just minus the letter?
                  • Kirk McHugh
                    #24
                    • Donald S.
                      • January 23, 2008
                      • 183
                      #25
                      AOS Job Number?????
                      since your talking job ## my 65 has a 333 on the bulk head in front of the tank on the inside of both doors as well as on the under side of the passenger toe kick area is this a job ## or just something to do with sequencing during assembly... thanks don...
                      • Donald S.
                        • January 23, 2008
                        • 183
                        #26
                        AOS Job Number?????
                        • Barbara S.
                          • April 30, 1981
                          • 599
                          #27
                          I found all three on my '67. Let me look at my photo archive when I did my body off. I know for a fact that the passenger side firewall and the gas tank bulk head did have L338 written in yellow grease pencil--same handwriting. However, the steel bird cage behind the dash was written in red grease pencil, and I think it only read 338. I'll check and re-post.
                          Tony
                          • Barbara S.
                            • April 30, 1981
                            • 599
                            #28
                            Tony
                            • Donald T.
                              • September 30, 2002
                              • 1319
                              #29
                              Re: AOS Job Number?????
                              "since your talking job ## my 65 has a 333 on the bulk head in front of the tank on the inside of both doors as well as on the under side of the passenger toe kick area is this a job ## or just something to do with sequencing during assembly... thanks don..."
                              Donald,
                              Your 333 is the job number for your car. Yours is typical of STL bodied cars which have job numbers ranging from 1-500, and they are typically found on the rear bulkhead, passenger firewall, and inside of the doors.
                              • Donald T.
                                • 1319
                                #30
                                Donald,
