'57 hard top correct Plexiglas date codes - NCRS Discussion Boards
  • Rex P Kelly
  • Andrew Anderson #31916
    Re: '57 hard top correct Plexiglas date codes
    Rex, if my math is correct you have a April car, the date code would be 4-7 or 4-57 for April or a 3-7 or 3-57 for March I think this is right, If not someone will let you know.
    • Rex P Kelly
      I think that is correct but, would the date code be the same as the month of completion of the car or up to maybe several months earlier What would be an acceptable range of dates???
        Ncrs G/M said Must be compatible with production date of vehicle, normally precedes vehicle assembly date no more than two months.
