First I want to thank all for the help I received over the last few months on my motor build. I started it last night for the first time. I had a few glitches with the rocker/lash adjustment, but after getting that straghtened out it ran like a champ. I ran it for about 20 minutes with no additional problems.
After the 20 minutes I let the idle slow a little to about 800 to 1000rpm. When I shut it down I experienced some diesel run on for several rotations with a little knocking. Upon initial start the ignition timing was about 22 degrees advanced, I set it at 12 degrees advance for the remainder of the break in. (With vacuum). The engine is built to lt-1 specs (cam, solid lifters, 11.0:1, etc)
Any ideas as to the cause of the run on. Could it be the timing not advanced far enough or possibly too much fuel. The Holley carb was set great before the engine build.
