Re: engine's first run
calculate the circumference of the balancer,divide this number by 10,then using a tape measure mark the balancer on the advance side of the TDC line. this will give you 36 degrees. now without the vacuum advance connected rev the engine till the timing mark stops moving,then move the distributor to set the new scribed line even with the "0" mark on the timing tab. removing one spring from the distributor advance will allow you to only have to rev the engine to about 1/2 the RPM to get full advance.
