Hi,
It looks like my field coil in the motor housing maybe burned. I can still run the motor to turn the headlights down, but there is no power(spark, movement etc.) when I put power to the contact of the motor to run the headlights up.
The paper cover of the coil has a burned mark suggesting the underlying wire got to hot. There was a screw in the motor housing where the support bracket attaches. Looking in the screw hole it looks like there was contact from the screw tip and the coil ( probably shorting the coil to the housing ). Can a coil be shorted out so it only carries current in on direction( from the down power terminal ) and not the other ( the up direction power terminal )?
The housing can't be openned, and the coil removed. Is there any way to repair or do I need to look for a new motor. If I need a new motor where should I look for one?
Thanks, Darwin
Thanks, Darwin
