Spark Plug Recommendations? 67 327/350 - NCRS Discussion Boards
    • 15610
    P.S.
    The double platinum long life plugs on new C5s are made by Denso.
      • 15610
      P.S.
      • Brandon K.
        • April 1, 1997
        • 474
        Do non-resistor plugs cause radio interference? *NM*
        • Brandon K.
          • April 1, 1997
          • 474
            • 15610
            Re: Do non-resistor plugs cause radio interference
            All I can tell you is that the OEM '67 plugs were the non-resistor variety, as were those om my '63. As long as I ran the Packard EMI suppression wires I didn't have any radio buzz with non-resistor plugs. I once installed some "Packard 440" solid metal core wires and the radio was useless,even with all the shielding and ground straps, etc. in place.
              • 15610
              • Brandon K.
                • April 1, 1997
                • 474
                Lectric Limited Repro plug wires
                I ordered some of the repro wires. Are they the same quality as the Packard suppression wires as far as radio interference goes?
                thanks, BK
                • Brandon K.
                  • April 1, 1997
                  • 474
                  thanks, BK
                    • 15610
                    #24
                    Re: Lectric Limited Repro plug wires
                    My wires are Packard EMI suppression. I have no experience with aftermarket or reproduction wires.
                      • 15610
                      #25
                      • Tom Merkel
                        #26
                        Re: Where do you get the 44's?
                        Brandon- If needed, I can try to get AC R44's for you. Blue, white and red box. Bold green stripe on plug top, with smaller green stripes on plug body. Assume # 5613865 on box to be Delco p/n.
                        Same for AC R43's. p/n 5569992.
                        Advise if interested.
                        With respect to the gentleman who commented about plugs manufactured after a certain date not to be of same OEM quality, I'll leave that for him to decide. I don't have any basis to comment on whether or not these are true OEM's or late repros. Tell me what to look for; I'll be glad to see.
                        Tom
                        • Tom Merkel
                          #27
                          Tom
                          • Craig S.
                            • June 30, 1997
                            • 2471
                            #28
                            Re: Spark Plug Recommendations? 67 327/350
                            I have several sets of 44's for my 67 that I bought at Carlisle and Bloomington. I agree, they run to perfection on 67 L79. Of course, they are being fired by an MSD 6AL and TI distributor that I will remove if I get around to judging, but in the meantime, the crisp performance and clean running to any RPM I dare go is great!....Craig
                            • Craig S.
                              • June 30, 1997
                              • 2471
                              #29
