C3 Master Cylinder Markings - NCRS Discussion Boards
  • jim34671
    Are the front stampings(such as PG,DC,etc) readily visible like the casting numbers or do they quickly fade away in time.Would media blasting reode them away? This for 1970-72 years.(Castings 5480346 and 5455509)
    I've yet to find these on very original pieces.
    Re: C3 Master Cylinder Markings
    Jim-----
    The broadcast code stampings on C3 master cylinders are usually very lightly stamped. And, yes, bead blasting usually does contribute to their further unreadability. However, I have rarely seen one that, upon close inspection, didn't have at least some vestige of the original stamping visible.
    SERVICE master cylinders sold during the 67-73 time period may or may not have had the broadcast code stamping, so it's POSSIBLE that some unstamped ones originated as SERVICE units. The broadcast code was primarily a PRODUCTION requirement.
