overheating engine problem? - NCRS Discussion Boards
  • Henry 36130
    I recently put Allen's off-road exhaust on my 65 327/365. Since then, I have experienced acceleration that is slightly off and overheating that causes stalling (after at least an hour of driving). I never had this problem before. The carburetor, timing, points are fine. Could the new pipes have anything to do with my loss of acceleration and the stalling?
  • Ed Jennings
    Re: overheating engine problem?
    If you have a heat riser in your right hand exhaust, check to see that it's opening. You may have disturbed something during the installation. I usually eliminate teh heat riser altogether by installing a spacer (originally used on FI cars) or wire the durn thing open. The counterweight should be pointing down if it's opening properly.
