Does anybody know if you can replace the brass bushings and door pins on a 1969 without removing the door?
If you have done this, how did you do it? Did you remove the door from the hinge or the door and hinge from the car?
Do the brass bushings have to be pressed into the hinge -- any special tools?
How about a source for the bushings and pins?
Jim #33086
Jim #33086
