oh no! i installed the holley 1850-2 [4160 vacuum secondary 600 cfm] the i just rebuilt. the car surged badly and would not idle. i noticed fuel dribbling from the main discharge nozzles even with the throttle plates closed. they were in the correct position at close, with just a very small bit of the transfer slots showing. i know that the float level is correct [definately below the sight plug], and my electric pump delivers a steady 6psi.
when i took it apart for inspection, i noticed that someone had filed the primary and secondary plates. there is a lot of light around them when the plates are in the maximally closed position. i suspect that there is enough air flow to send a signal to the main metering system which causes fuel to flow from the main discharge nozzles, even at "idle". the gaskets are correct. before i buy new plates, does anyone have any other explanations for this??
any help would be appreciated.
