Re: crank bolt
the starter bendix is completely released when the starter is not spinning the engine so the starter has no drag on the engine. if you can not rotate the engine in the reverse direction with the damper bolt just install longer bolts in the 3 places that hold on the bottom pulley and use a bar between them to turn the engine. i always use red loctite on the damper bolt so that is why i have no problem turning the engine backwards.
