56 speedometer drive gear
  • Steve Junkersfeld
    Does anyone have the correct speedometer drive gear tooth count for C-1s that corresponds to the various differential ratios? I have an assortment of drive gears but do not know which cooresponds to 3.70s, 3.55s, etc. I thought the ST-12 might have it - but can't find it anywhere. Thanks Steve
  • Joe Lucia (12484)
    • 42936
    Re: 56 speedometer drive gear
    Steve-----
    The following will GENERALLY be the case for C1s. However, there are too many factors which get involved and complicate things to make a RULE out of this subject. ALL of the following assume STOCK tire size and/or OD:
    3.08:1= 20 tooth count (61-62)
    3.27:1= 19 tooth count) (1956-only)
    3.36:1= 20 tooth count (61-62)
    3.55:1= 21 tooth count
    3.70:1= 22 tooth count
    4.11:1= 24 tooth count
    4.56:1= 20 tooth count STEEL gear (used with different DRIVE gear)
    • Steve Junkersfeld
      Joe, As usual - You Da man! Thanks for the info. It should save me from swapping gears under the 56 after the body is back on. Steve
