If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I am looking for a spark plug recommendation for a stock '68 L79. Actually, it does have a Pertronix in it, if that matters. This is for everyday driving and not a judging situation. TIA
AC 45s always work best for normal driving in all small blocks, but AC no longer makes non-resistor plugs, so I recommend the NGK B4 or Denso W14-U. If you want to use resistor plugs AC R45s are fine, and you can cross these to many other brands, but be sure you get the equivalent to AC heat range "5". (The "4" in 45 means that it is a 14 mm thread.)
Thanks! I wondered what the 45 stood for. I'm pretty sure it has AC45s in it now. I was wondering if there might be something like a Rapidfire plug that would work well.
Depending on your driving situation, RJ-14YC's may work better for you - the Champion 12's are equivalent to AC 44's, and the 14's are equivalent to AC 45's. I run either AC R45S or Champion RJ-14YC in both of my small-blocks ('69 Z/28 and '67 Corvette 327/300) and no longer have any of the fouling problems I used to have with AC 44's.
I don't understand all this hysteria over spark plugs. AC 45 or 45S will work fine as will Champion J-12 or J-12y. I forget the Autolite number. They all work well in my experience. The tuning of your engine has far more to do with your engine running well than your plugs. If the spark and fuel are correct. the plugs will last a long time. Any of the name brands. Again, in my experience.
If it makes you feel better to go to E-bay and buy a set of "original" plugs for your car, go ahead. I buy mine from Wal-mart for about a buck apiece. I don't change them until they start missing at the speed I drive at. That means the plugs in my old cars are 10-15 years old because they don't get driven all that much. Something to think about!
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
