My wiper motor will not turn off unless I disconnect the ground wire at the wiper motor. The wipers have both speeds but when I turn the switch off the wipers stay in the slow speed. Thanks, Dave
1966 wiper motor
Re: 1966 wiper motor
Dave:
Within the wiper transmission housing, there are 2 solenoids. One is for the washer pump, the other is to engage the parking mechanism. It is very likely that this parking solenoid is "open". Much less likely that the parking pawl is broken or missing. Try to shut off the wipers, and have a friend listen for a click---if you hear it, then that eliminates the solenoid as the problem. I recall that there are 2 very small springs which may be included in the park mechanism. If they are involved then check the exploded view in the Shop Manual to see if they are there.
Joe- Top
