C2 '66 BB radiator question
  • Tom Merkel
    #1
    Gentlemen: Am looking for advice on a replacement rad for my '66 BB, no powers. My current one leaks slightly and I want to fix that for good.
    Was the original one AL or CU core? Perhaps I should take a look at DeWitt's??
    Thanks.
    Tom
    • 9893
    Re: C2 '66 BB radiator question
    All '66 BB cars used a brass radiator (3008567 on MT and 3008566 on AT). These can be disassembled and rebuilt quite nicely by a competent local radiator shop in your area. DeWitts isn't making a full reproduction of these radiators to my knowledge, just the inlet/outlet 'tank' sections for local rad shops to use in rebuilding badly damaged Harrison originals. I'm sure Tom DeWitt will step in and correct me if I'm wrong on this....
    • Larry Rosamond
      I believe DeWitt's has cores available
      Jack, I may be mistaken, but DeWiit's has correct cores, not end tanks, for the 66-67 (and 68-69?) big block copper radiators. One would hopefully have the original end tanks to recore. The reason I know is it took me 6 months and $700 to find a radiator restorer to redo mine and then DeWitt's came out with their correct cores for a reasonable $249 shortly afterwards.
      Of course, now Tom will correct me.
      Regards, Larry
        • 15229
        Read...
        this entire thread.
        • Tom Merkel
          C2 rad dexcool?
          Read that referenced thread, Duke. Good info. But what is Dexcool? An antifreeze of some sort? And what is the underlining problem with a garden variety antifreeze, such as Prestone? Salts distilling out?
          I'm concerned because I just installed a new DeWitt's in my '67 SB last summer and filled it with 50/50 antifreeze and distilled H2O. If there is something prudent I should do now early-on, I'd very much like to be aware of it.
          Thanks.
          Tom
          • Bryan L.
            • July 1, 1998
            • 11
            Re: I believe DeWitt's has cores available
            At one time Dewitt's had a limited number of NOS side tanks and could make up a complete, correct, brass/copper big block radiator. I have a beautiful example in my garage.
            BL
