How to bench test C2 horns - NCRS Discussion Boards
  • Bill W.
    • March 1, 1980
    • 2000
    What is the best way to bench test a C2 horn without causing damage ?
  • Keith B.
    • March 7, 2008
    • 928
    Re: How to bench test C2 horns
    Put 12 volts to the plug and gound out any other part of the horn.
    • Joe R.
      • May 31, 2006
      • 1822
      Keith,
      You pretty much nailed it. The only thing I would add is a fuse or a current limited power supply. What gauge is the wire feeding the horn?
      Joe
        • 6940
        Bill, Don't forget when the horn is painted you'll need to remove some paint to get a good grounding surface.
        • Bill W.
          • March 1, 1980
          • 2000
          I read somewhere that if you used a 12 volt battery to test the horn you could damage it by not going through the horn relay ?
          • Stephen L.
            • May 31, 1984
            • 3148
            12v is 12v...... no matter if the voltage passes thru a relay or not. Just hook a jumper wire from the positive battery pole to the horn connector and another wire from the negative pole to the horn bracket. You don't need a fuse for this temporary test... if there is a short, the small jumper wire will serve as the fuse........
            • Mike E.
              • June 24, 2012
              • 920
              Just be ready when it works. No matter hard you prepare yourself for blast don't drop it. It's likely that it will scare the hell out of you when it blows the first time.
              Mike
