Does anyone know the headmarks and types of fasteners for mounting the antenna, changing antenna to original and thought I might as well get the fasteners correct. thanks JR
65 antenna mounting fasteners (three)
Re: 65 antenna mounting fasteners (three)
Looking at a loose mount bracket and (inner fender) backing plate that I happen to have, looks like the two bolts are recessed hex with 4 rings and a stylized "ELH" in the middle, and cross-hair lines. Don't have the third bolt that mounts the bracket to the antenna motor case, but it could be the same. Can post a pic of the two in a few hours, if needed.
Upgraded operating system and have to re-load my photo editor
- Top
wayne I found your photos of the bolts on a thread search. JRLooking at a loose mount bracket and (inner fender) backing plate that I happen to have, looks like the two bolts are recessed hex with 4 rings and a stylized "ELH" in the middle, and cross-hair lines. Don't have the third bolt that mounts the bracket to the antenna motor case, but it could be the same. Can post a pic of the two in a few hours, if needed. Upgraded operating system and have to re-load my photo editor
.JR- Top
