65 antenna mounting fasteners (three) - NCRS Discussion Boards
  • Jim R.
    • June 30, 2001
    • 643
    Does anyone know the headmarks and types of fasteners for mounting the antenna, changing antenna to original and thought I might as well get the fasteners correct. thanks JR
    JR
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 65 antenna mounting fasteners (three)
    Looking at a loose mount bracket and (inner fender) backing plate that I happen to have, looks like the two bolts are recessed hex with 4 rings and a stylized "ELH" in the middle, and cross-hair lines. Don't have the third bolt that mounts the bracket to the antenna motor case, but it could be the same. Can post a pic of the two in a few hours, if needed.
    Upgraded operating system and have to re-load my photo editor .
    • Jim R.
      • June 30, 2001
      • 643
      Hi Wayne I think the motor case is a sems recessed with star washer and was thinking all three may be sems, I suppose they may have used severall types, pics are always good if you can. JR
      JR
      • Jim R.
        • June 30, 2001
        • 643
        wayne I found your photos of the bolts on a thread search. JR
        Originally posted by Wayne Midkiff (3437)
        Looking at a loose mount bracket and (inner fender) backing plate that I happen to have, looks like the two bolts are recessed hex with 4 rings and a stylized "ELH" in the middle, and cross-hair lines. Don't have the third bolt that mounts the bracket to the antenna motor case, but it could be the same. Can post a pic of the two in a few hours, if needed. Upgraded operating system and have to re-load my photo editor .
        JR
