I have a 67 clock with a burned out coil. Is there a source for replacement parts? What would cause the coil to burn out?
C2 clock coil
Tags: None
- Top
Re: C2 clock coil
These guys will do it for you for $30....maybe they'll sell you the coil:
- Top
Re: C2 clock coil
The points sticking when the coil is energized. It seems like if you use a really cheap battery charger that does not output clean DC and have the cables connected while charging it can cause issues.
Mike- Top
Re: C2 clock coil
Pat, I believe if the battery goes low or dead this will cause the clock to cycle many times and fuse the points which overheats the circuit.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: C2 clock coil
Thanks for the information. It sounds like burned out coils may be a common problem. I wonder if the coils are unique to Corvettes or common to most GM cars of the era?- Top
