C2 clock coil - NCRS Discussion Boards
C2 clock coil
  • Patrick B.
    • August 31, 1985
    • 1986
    C2 clock coil
    I have a 67 clock with a burned out coil. Is there a source for replacement parts? What would cause the coil to burn out?
  • Frank D.
    • December 27, 2007
    • 2703
    Re: C2 clock coil
    These guys will do it for you for $30....maybe they'll sell you the coil:
    • Mike E.
      • June 24, 2012
      • 920
      Re: C2 clock coil
      The points sticking when the coil is energized. It seems like if you use a really cheap battery charger that does not output clean DC and have the cables connected while charging it can cause issues.
      Mike
        • 6940
        Re: C2 clock coil
        Pat, I believe if the battery goes low or dead this will cause the clock to cycle many times and fuse the points which overheats the circuit.
        • Patrick B.
          • August 31, 1985
          • 1986
          Re: C2 clock coil
          Thanks for the information. It sounds like burned out coils may be a common problem. I wonder if the coils are unique to Corvettes or common to most GM cars of the era?
          • Larry M.
            • January 1, 1992
            • 2688
            Re: C2 clock coil
            Pat:
            I am almost certain that the coils were common to most models. The clock sizes and faces were obviously different.
            Rebuilding should not be an issue. Frank gave you the place.
            Larry
