Ok guys, I really need your help. I did a total 100% frame off restoration on my 62 corvette that I finished back in 2006. Here is the problem that started 2 years ago. I did not drive the car much because of this. While driving the car, at different times the engine sounds like it shuts off & on in a split second. I parked the car in the garage with the head lights on & engine running at idle. As I sat in the car the engine and the lights would shut off & on in a split second. I noticed the ammeter went all the way down to the negative side then back up to near zero. I replaced the Ignition Switch, Starter Solenoid, Voltage Regulator, Coil, no luck. There is a 12 gauge wire that feeds from the starter solenoid to the ammeter. I by passed that by running a 12 gauge wire from the Battery directly to the wires on the other side of the ammeter thinking maybe the old wire or ammeter was at fault. No luck.I checked out the Battery and the Generator at a shop and they checked out good. I cleaned the grounds on top of the engine.Are there any other grounds i'm not seeing that could be causing this? Any help would be greatly appreciated. I want to enjoy my vette again. You may also email me at clasvette@aol.com
Thanks for all your answers in advance.....John
