66 Hazard Flasher - Need some help - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1273
    Re: 66 Hazard Flasher - Need some help
    Hi,
    I just bought a 1966 with this hazard warning switch installed. It works only with the headlights on and a little weaker with the parking lights on. Is this the proper operation for this flasher system?
    Jerry
    • Mike T.
      • January 1, 1992
      • 568
      Jerry - I added the 4-Way Hazard Flasher to both my 65 and 66 Coupes and I just went out to check the operation on the 65 and found the 4-way works with key off, no need to activate anything else. I may not have it in the correct fuse panel receptacle as the instructions say in my other post above, #13 but they function well. Where does your hazard flasher setup plug into the fuse panel? Here's a pic of mine on the 65. You can just see a trace of the orange wire on the bottom left connector.
      Mike T. - Prescott AZ.
      • Gerald C.
        • June 30, 1987
        • 1273
        Mike,
        My orange wire is in the "acc" port. I will move it to the lower left corner of the fuse panel "Batt"
        Jerry
