What's the best practice for venting when using a modern replacement battery in a C3?
I searched the Forum and the most relevant post I found is this entry by KEN BUTCHER in this 2005 thread:
I don't believe all modern batteries have vent ports, but some do. I own a '93 Cadillac Allante which uses a sealed, side terminal battery installed behind the seat. Its battery has a vent port on each end near the top, which connects to these vent tubes on the Allante:
The Allante's ACDelco battery part number is 78VPS; its description on the ACDelco website:
Its dimensions, 10" long x 6.7" wide x 7.5" high, are close to the dimensions of R89W Corvette Reproduction Battery for the '70 Corvette
"...if you have a modern battery and not the repro you can still put the two vent tubes on. Because the modern batteries don't have caps on top and are considered maintenance free, they still have vent outlets, which if you look closely are on the top to the side. They look like small oval tubes. If you want to attach the rubber tubes to the small oval tubes, here is an idea. It worked for me. Go to a parts store that sells electrical connectors and you should be able to find a connector that has a sleeve that is the same shape and will fit over the vent tube on the battery. The other end is round like the rubber vent tube. Since it is an electrical connector you will have to remove the metal clip inside the connector. When you get that done the rubber tube fits over the round end of the electrical connector and the oval end fits over the vent tube on the battery."
Silver BCI Group 78 Battery
Part Number: 78VPS
BCI 78 CCA 770, Battery is vented to outside of the vehicle
Part Number: 78VPS
