After a good run yesterday I noticed my pump was bubbling and forcing a small amount of gas out the bowl. In my case after the pump was rebuilt it was delivering about 8 psi which overpowered the carbs. They're supposed to run under 5 psi. I was forced to put a 4 # regulator on it. Is this a common issue with these pumps? How does the pump relieve the pressure? Any thoughts?? Thanks.
