Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 C2 Tar Top Battery Configuration Issue - NCRS Discussion Boards
  • Bill L.
    • April 1, 1985
    • 349
    Re: C2 Tar Top Battery Configuration Issue
    Originally posted by William Clupper (618)
    At least on all the Tar top configurations I have in Delco Catalogs from the mid-60's the raised areas should be visible from the top.
    Bill....
    Thanks... I think that is the key item.... it would seem that the catalog photos would verify the raised areas.... I have done a few searches but have not been able to find anything....
    Thanks!!!
    Regards
    Bill
    • William C.
      • May 31, 1975
      • 6037
      1966 Chassis service manual Section 6Y shows a good picture of the battery configuration being discussed here....
      Bill Clupper #618
      • Jim S.
        • March 1, 1986
        • 1392
        #18
        [QUOTE=Gary Jaynes (3503);778110]Maybe someone has a picture of a Real Tar Top they would like to share. Aren't there some raised pads running horizontal between the positive and negative post?
        So if the $300.00 plus Restoration Battery is getting a 7 point deduct, would you not be better off putting in a Delco Service Replacement Battery and taking the 12 point deduct? At least you would have money in your pocket.
        You would think that if Restoration Battery would fix the problem, but that is like everything else. Why not make it correct the first time![/QUOT
        Here is a picture of the raised pads you speak of . I however have no idea if they are appropriate at all , or appropriate for only certain years.
        Could this be the raised areas the judges were speaking of ??
        Reading this thread closely as I am just about ready to purchase a battery myself.
        Jim
        • William C.
          • May 31, 1975
          • 6037
          #19
          Looks just like the one shown in the '66 service manual I referenced last evening...Should be good...
          Bill Clupper #618
          • Bill L.
            • April 1, 1985
            • 349
            #20
            HI:
            This seems to be a bit clearer now.... the battery that Bill C. referenced in the '66 service manual is here:
            ....and of course the photo Jim S. provided has the raised areas ---- labeled "Protected Cell Connector" in the photo above ......
            I am making the assumption now that those raised areas (or lack of them) on some batteries were getting a deduction for configuration ---
            Thanks to everyone who chipped in on this!!!
            Regards
            Bill
            • Jim S.
              • March 1, 1986
              • 1392
              #21
              Originally posted by Bill Lucia (8620)
              HI:
              Regards
              Bill
              Bill ,
              I offered up that picture as a possible explanation . I was hoping that someone who knows for sure would have replied so you and I wouldn't have to make that assumption !
              For one thing , even if that is the raised areas the judges spoke of , are they correct for a 66 battery ? If you look closely at my picture ,that particular battery is not correct for a 66 Corvette, it's just the only picture I could find with the raised areas on top . Secondly , even though it somewhat matches the picture in the Service Manual, the Manual was printed in 65 and I suspect that picture was right out of the 63 SM, if not even earlier .
              In short , it looks like the Delco DC 12 battery was used from 61 through 66. Were the raised areas there for the entire run ? It appears Restoration Battery doesn't think so . Inquiring Minds , as well as someone who is about to order one , Want To Know !
              Jim
              xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxx
              • Ronald L.
                • October 18, 2009
                • 3248
                #22
                Curious that no one ever answered if these raised pads are correct for a 66?
                Or ANY DC-12 for that matter. IMHO Those raised pads were a 50's thing. I have no less that 4 vintage batteries, DC-12 with Delco dates and I fail to see those pads, but I have seen them on 40's era 6 volt Ford cells.
                • Joe R.
                  • July 31, 1976
                  • 4547
                  #23
                  This is a real Tar Top Delco batttery . I have just posted so every battery expert can see what the top of a Delco Tar Top really looks like.
                  Looks like the reproduction battery really is a great copy of what Delco originally made.
                  If there is such a problem with reproduction batteries why aren't the radiators, hoses, belts, seat covers, carpets, door panels, emblems etc. etc. discriminated against like the batteries.
                  Nearly every Corvette shown at NCRS events should be called repo-mobiles anyway!
                  • Michael J.
                    • January 27, 2009
                    • 7073
                    #24
                    I totally agree Joe, well said. It is the biggest frustration on judging I have encountered, where dead nuts on reproductions get a big deduction just because they are not originals. So many other reproductions get by fine, makes no sense.
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      #25
                      Joe
                      Question on the battery
                      What year? 65?
                      F5N date code translates to?
                      June 65. N plant?
                      Has a 66 notch?
                      • Joe R.
                        • July 31, 1976
                        • 4547
                        #26
                        Ron,
                        That's a 959 Delco batttery which was used in a truck. Just showing it to display what the top of a real tar top battery looks like from the 60's! The 959 Delco Battery is about 1/2" taller and is designated a Heavy Duty Battery by Delco. Don't know the date codes. Used that battery in a 63 I campaigned back in 1993.
                        JR
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          #27
                          As I replied to the other thread, I have one identical to your 250 with the LIC date code. Neither date code fit the model that Restoration Battery had published.
                          Nor does it account for post dating. Was date stamped NEG post a service only operation?
                          Other than size, there is one obvious difference to a real DC12 - on the top, what is it?
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            #28
                            I can see why you guys are struggling with AAB, the answers you get. I asked about the F5N date code and they said it wasn't real, then the L1C and she told me it was March build date fo the car, OMG, we have good factual data sources here. Never got an answer if the 63-65 configuration had a flange notch yes or no...
                            • Danny P.
                              • Today
                              #29
                              At the Regionals this summer i got deducted 7pts. because of the top lip of the Battery had a groove and it should of been smooth
                              • Ronald L.
                                • October 18, 2009
                                • 3248
                                #30
                                Does Anyone Have a picture of a real 1966 battery with the notches at the bottom?
