I want to install a new alternator. 1962 327ci. 4 speed. Need help into what kind of alternator should i use?
Alternator 1962 new
Re: Alternator1962 new
62 corvettes used generators, not alternators. however, any first generation GM alternator(with external regulator), will mount using gm bracketry. 2nd generation gm alternators, with internal regulators, will also mount using gm bracketry . mike- Top
thank you mike
i have a voltage regulator on the car and it is new- Top
Ed
Understand this is not a "restoration" action putting an alternator as Mike said. But if you are dead set on an alternator there are plenty of step by step procedures and availability on the inter web. Here are a few to get you started some dealers some tech.
DB Electric offers top aftermarket parts nationwide for auto, boat, and industrial needs. Discover quality and reliability now!
http://bob_skelly.home.comcast.net/~...ternator1.html
http://67-72chevytrucks.com/vboard/s...d.php?t=604881- Top
Ed
Make sure you read the one from Mad Electric mentioned by Gene, especially the article about one wire alternators! Mark is a wealth of information, but as John Hickley once told me there are only two things wrong, one, he is hard to reach by phone and two he is hard to get off the phone, LOL. He was a tremendous help to me in rewiring my 62 for an alternator, stereo with two amps, changing the amp gauge to a volt meter.
Terry- Top
Re: Alternator 1962 new
A "new" alternator ?
Meaning you are already running one...
If not, what is wrong with your generator ?
Unless you've added a bunch of accessories a generator works perfectly..
I ran the original in my '61 for a dozen years including driving a 650W stereo amp...- Top
