The owners manual for my '66 L79 with it's original K19 system calls for dwell of 28 - 32 degrees, timing of 10 degrees BTDC with vacuum advance disconnected and plugged. I'm running the correct AC44 plugs. Are these the best settings for good idle quality and smooth acceleration, or should I make some changes in timing? The vacuum advance is a 236 (repro from LIC).
Would appreciate any advice -
Bob
Bob
